BruceH
BBB Big Bore Boss 322
Most...if you are supercharged. Not sure about the turbo guys though.
I know for a fact, having both coils on the bench that they are not the same coils externally. The older coils have a slightly larger diameter where the spring is inserted. Plus, the spring on the older plugs is shorter than the newer plugs. Obviously, the boot is also different in length.
Internally (electronically) the coils most likely are the same.
How can your knock sensors be on for part throttle and then off for WOT?
Aren't they on or off...?
This is news to me. I doubt that most tuners turn them off with the s197. There just isn't a reason to do it. If a particular combination is showing false knock then the ks function can be modified in the tune. It can be shut off completely but it can also be adjusted via a table for problem areas.
As you know I'm one of those guys who keeps the fail safe protection on unless it just can't be used. I can't think of one fail safe I've had to turn off.
I'll post a screen shot of the ks tables in a little bit.
Edit: This will give you an idea of what's available for the ks.
Honestly at this point I think it was the gas too. But this didnt happen all at once it was over a couple is weeks. My thought originally was that the proper spark needed more fuel and I didn't know it. I had just swapped the exhaust for emissions within the last month too and I thought I just had an exhaust leak at first. It wasn't until I saw some blue smoke that I realized I had other problems.
In theory I could have hurt it a little each time I got on it trying to figure out the exhaust leak.
What did you swap out exhaust wise?
