W3bb3r04
Slow 3v Member
Zone 5 mega driver module. This allows you to run 2 or even 3 pumps off the factory FPDM signal. It acts as a boost a pump in the same sense. Basically this will can replace the need for dual FPDM and also gives you a boost a pump function or you can run 3 pumps if you'd like. I was going to use it with my triple pump set up but I decided to go return so it will not work with my set up since voltage to the pumps is controlled by the FPDM signal. It comes with all plugs and most wiring. The most you may need is to lengthen some wires and solder or splice some wires. I'm asking $200 shipped. For the functionality you get I think it is worth that. I will take reasonable offers though.
