While we're on the subject of using parts that were not a part of the actual 3V setup, when installing the iron tensioners what is everying using to seal them to the block?
The stock plastic 3V tensioners have a built in gasket, while the iron tensioners don't.
So, is there even a seal needed or is it a situation where it sits so flush with the block that you don't need one since the pistons are "locked" in their farthest extension?
I've always used the plastic tensioners. The iron ones are designed to be used without a gasket like you mentioned.
