Tsb 11-07-07
TimMcc
______________
Indian Land, SC
Got a text from my tech friend at a local Ford dealer just a bit ago...
It read" "Blown up Coyote motor...more likely than you think"
I responded with cylinder # 8?
He called like two seconds after and asked how I knew. This is the first one they have seen at that dealer.
The car had an aftermarket tune in it and was returned to stock.
Not sure who tuned the car, but it had a major site sponsor's ''that is regularly covered in magazines'' stickers on the car.
I will try to get more information, it's suspected the altered knock sensor calibration led to the engine malfunction. I asked him how he could verify that...not sure how you could unless you saw the actual tune file.
Warranty has been voided.
Tib02
Houston, TX
got a text from my tech friend at a local ford dealer just a bit ago...
It read" "blown up coyote motor...more likely than you think"
i responded with cylinder # 8?
He called like two seconds after and asked how i knew. This is the first one they have seen at that dealer.
fffffffuuuuuuuuuuuu
Riptide
Will work for Mustang.
Montucky
Yikes. Another one bites the dust.
19COBRA93
Ford Racing
Clinton, Ut
Yes, that's why it is a higher octane. But 93 octane pump gas is 93 octane, period. If it has 10% ethanol, it is STILL 93 octane.
Sent from my DROID2 Global using tapa-whatzit-thing
The fact that it burn cooler has nothing to do with the octane rating. Higher octane fuel burns slower, but not necessarily cooler. Ethonal burns cooler and slower. That's something that higher octane gasoline doesn't do.
93 octane e10 will burn cooler than 93 octane pure gasoline. Cooler combustion temps will help with detonation control.
DON SVO
Ethanol burns cooler.
... and it takes more ethanol to equate the energy output of gasoline. Hence the fuel economy drop off associated with E10 gas. From a pure octane perspective, there is no realistic difference. With a blend devised to mimick petro-gas octane ratings, the cooling properties of ethanol are severely comprimised. I don't feel that an inadequate tune can be saved with E10 fuel. Several of these #8 cylinder fail-boat tunes were using E10.
tigerhonaker
TN
Ford TSB: Dont Modify Your 2011-2012 Mustang 5.0!!!~
I looked and did not see this Posted so ..........
http://www.fnsweet.com/2011/07/ford-...2-mustang-5-0/
Ford TSB: Don't Modify Your 2011-2012 Mustang 5.0!
By Sam HaymartPublished: July 9, 2011Tags: 2011, 2012, 5.0, ford, mods, Mustang, TSB
timthumb.php
Ford has tidal waves throughout the Mustang modding
realm this week, issuing a new Technical Service
Bulletin (TSB) to dealers that essentially says, “If an
owner has modified their 2011-2012 Mustang 5.0
drivetrain, their warranty is void”.
TSB 11-7-7 warns Ford Service Departments that when
servicing 2011-2012 Mustangs with the new 5.0 liter
engine, to look for modifications the owner may have
made before covering a list of engine and drivetrain
failures.
The new 5.0 liter 32V DOHC Coyote engine has been
widely received as one of the best new engines Ford
has ever produced. But what a lot of shade tree
mechanics don’t know or overlook is that this high
compression engine is near maxed out structurally at is
factory specified power output.
The TSB warms that common modifications done by a
lot of owners that increase the power output can cause
premature failure of not only a number of engine
components, but drivetrain systems like clutch and
gears.
Ford has been in the business of encouraging its owners
to customize their cars in the past decade, in fact even
offering a raft of products though their dealers to do
just that. But the company is sending out a warning
shot that they will be voiding warranties if it is
determined that modifications made by the owner are
the cause of failures.
tigerhonaker
hawkeye18
omgwtfbbq
Good info, but it's, uh, been pretty well known for at least two weeks now.
Fullboogie
King of the Ski - OG Jr.
Houston
It may be that Ford is becoming more "diligent" on looking for mods, but it doesn't change warranty law that is already in place.
fdjizm
Drag Queen
I never knew why this was big news (I don't mean your thread tiger) just the fact that people are shocked they won't warranty an engine YOU messed up. It's been like that since forever. lol
tigerhonaker
TN
This is True and I have Warned the un-knowing that if you are Concerned over Warranty.
(Don't Screw with your Car Modding it)
tigerhonaker
lostsoul
2014 vett or 2015 stang..
Gay Area
Well the good news is I can go out and whoop ass on 5.0's and only a very few with cash to burn will take the chance to mod.. looks like I'll have to save for a slowbra
Bmr4life
2005 GT
Atlanta
Pretty sure the ones you run into at the track will be modded sir.
tbi0904
Huntley, IL
Wishfull thinking dude. Personally I have no fear of swapping my 08 for a 5.0 in couple years. Tuners will have it figured out long before then.
Riptide
Montucky
He's got north of 500whp. It's not like he'll have problems beating a lot of 5.0 cars in the first place. They will need something more than bolt ons to hang with that more than likely.
