BoostedGt480's Build Thread
tigerhonaker
TN
If I lived closer I would liked to have watcked this take place.
Everything looks just so-so ........
tigerhonaker
BoostedGT480
Slow 3v
Montgomery, AL
Progress today:
Mounted radiator fan, coolant tank, ps tank, ecu, water cross over, oil relocation kit, mounted the intercooler pump, hooked up a few hoses, mounted ac and put on 8 rib pulley, mounted ps pump and installed 8 rib pulley
Pics
UltraKla$$ic
PERENNIAL WAXXER
Louisiana
It looks amazing!!! Good luck keeping that beauty clean though. That White is going to be murder to keep clean. LOL!
BoostedGT480
Slow 3v
Montgomery, AL
Thanks guys...Hopefully Monday I will be able to do the tranny, driveshaft, exhaust, and then start the wiring procedure...then its hooking up the dual BAP and turning the key over..Whoop whoop!
UltraKla$$ic
PERENNIAL WAXXER
Louisiana
Can I have the valve covers, front timing cover and radiator cover? PLEEEEEEEEEEEEEEEEEEEEEEEEEEEEEAAAse?!?!?!?!?:lol2::lol2: I can't stop looking at it.:beer:
Randy_S_14
Fort Riley, Kansas
Progress today:
Pics
IMG]http://i405.photobucket.com/albums/pp132/Pro2xx/MustangGT/P1050882.jpg[/IMG]
IMG]http://i405.photobucket.com/albums/pp132/Pro2xx/MustangGT/P1050883.jpg[/IMG]
IMG]http://i405.photobucket.com/albums/pp132/Pro2xx/MustangGT/P1050884.jpg[/IMG]
IMG]http://i405.photobucket.com/albums/pp132/Pro2xx/MustangGT/P1050885.jpg[/IMG]
IMG]http://i405.photobucket.com/albums/pp132/Pro2xx/MustangGT/P1050886.jpg[/IMG]
IMG]http://i405.photobucket.com/albums/pp132/Pro2xx/MustangGT/P1050887.jpg[/IMG]
IMG]http://i405.photobucket.com/albums/pp132/Pro2xx/MustangGT/P1050888.jpg[/IMG]
MOAR!!!!:beer:
BoostedGT480
Slow 3v
Montgomery, AL
Todays progess = not much. Just put the ground on the driverside head, bolted in steering rack, and rack and pinion.
Tomorrow should be a good day. Planning on mounting tranny, shifter, driveshaft, driveshaft loop, exhaust, and then going up top to mount the manifold, KB, alternator, and all accessories. Will have alot more pics of the progress!
SherrodMustang
Montgomery, Alabama
Take a break, it is 3:00 am and you are still working on that car hooking up wires..... LOL!
Just messing with you, let me know when you get close to starting it up.
BoostedGT480
Slow 3v
Montgomery, AL
I just pulled an ALLLLLL NIGHTER! and you can ask the guy above! lol
Got the tranny mounted, cross member mounted, wiring harness COMPLETE, exhaust hooked back up, alternator on, manifold on, KENNE BELL on, throttle body on, and a few other things I probably forgot...
All thats left is hook up driveshaft, new hoses, intake, zip tie all loose wires, and put on my belt...Oh, and complete my BAP wiring. Getting close!
Pics coming later - I got to head to work now...This should be interesting
UltraKla$$ic
PERENNIAL WAXXER
Louisiana
:rockband::allhail:
You must be young, I could've done the ALLNIGHTER...............................20 years ago. LOL!!!!:beer:
