How much nitrous
blacks197
Albuquerque,NM
351inside- are you still using the kit I sold you? If so there are the correct jets for a 125 shot that I bought from nitrous outlet
Sent from my Mind using the Darkside of the Swartz
boduke0220
depends on how often you spray it IMO. i dont see why it wouldnt, people have ran blowers and nitrous on all the previous mustangs for years at a time without issue, and the 5.0 is way stronger.
351inside
Houston Tx
Im in the process of intalling the kit, i got all the jets still, but only see the ones listed on the little bussiness card. Theres a couple of extra jets in there, if you know which ones are the ones for a 125 let me know.
blacks197
Albuquerque,NM
There wasn't a jetting for 125 on the card when I got the plate.
Graham2
from my understanding, the only two "good" options right now for a nitrous setup (100-150 shot) are
Brisk RR14S
Autolite HT01
I would not want to use that Autolite. IMO I would only use the Brisk plugs as of right now.
Nastystang06
Mt. Pleasant, Tx
I don't think you need a tune for a wet kit unless your pulling timingg and I don't plan on pulling any for a 50 shot
I ran a 75 shot on my 3v and pulled no timing... did great!
351inside
Houston Tx
Yeah I.had a 75 shot with my regular tune also on stock plugs, it ran great...
I was just wondering if these motors we could run the same regular tune and srock plugs with a 50 shot
Torched S197
Somerset, Ky
Anything under a 100 shot does not need a tune or timing pulled! So I wouldn't see it a problem running a 50 shot on stock plugs! I ran a 100 shot on stock plugs for about 2 bottles and it ran fine until they finally gave out
gtmiller1001
Houston
Anyone? ?
I don't think so but I have no dyno #'s or track times to back that statement up.
I have the brisk plugs in mine and when running them on the same NA tune I had prior to the Nitrous I can tell no difference at all in the butt dyno. Mine are gapped to .033.
I can say that I logged the car before and after the brisk plugs with the same TORQ tune and had absolutely zero knock either way.
