I need help now! my windows wont go up!
G.AlMuhairi
Dubai
Hey,
I was working on installing my boost gauge with Roush vent pod, before I moved the gauge it was connected to a blue wire behind the storage compt. on the passenger side, I opened the wire from the gauge and now my windows wont go up! did I burn a fuse? any idea what the problem is?
its 50c+ cant drive with windows down! LOL
G.AlMuhairi
Dubai
i checked the fuse box on the passenger side, nothing wrong with them! F44,F5,F12,F11,F6
there is nothing wrong with them!, and now i noticed that my rear view camera on the rear view mirror is not working.
any idea why?
Look in your owner's manual, might be one of the fuses in the box under the hood? I don't know, good luck finding it.
Hawgman
THE fucking bad guy
Why the fuck would anyone want to live where the temp was over 120 degrees??
Not really sure how we are supposed to help with the rear view camera not working if we do not know what circuit you are drawing the power for the camera from. But whatever circuit it is (reverse switch, reverse lights, or whatever) that would probably be a good place to start looking.
I don't have an owners manual for your year model car, only for mine. So I can't tell you fuse positions and be positive they are the same. But.... if they are the same, why are you checking fuses 11 and 12? Those are rear window motor fuses for convertibles only.
Racingtheburg
Check all fuses over inside and outside. Undo power on battery and let sit for a minute or two and then try it. The wire you messed with make sure it is not open and grounding itself out.
Hope it helps!
G.AlMuhairi
Dubai
someone told me to reset the windows module, and the way to do it I've sent the car with a recovery to the garage to check and its time to start the build.
Quote:
Zero tax :beerdrink:
Enough said :)
