Charging System Problems
Mustang30212
Columbus, Ga.
Aw man...just goober some solder on it and ride!! lol
Glad you got it figured out...I hate electrical gremlins.
RH
Mustang30212
Columbus, Ga.
BTW....that wire looks cut.
I'll get your door handles shipped out Monday. I went to UPS today and forgot all about them.
RH
tmcolegr
It's All About the Build
Central, FL
What was the voltage at the (+) battery terminal on the back of the alternator?
FOUND IT!!!
This is the wire that is running from my power wire to the alternator...The other day I noticed smoking and noticed that wire loom got close to the header...Well I didn't think it went all the way through....Well the pic shows otherwise
That wire wasn't cut. That is the OEM 8 gage fusible link that is burned in half. The alternator (+) wire or alternator itself has obviously shorted out and the fusible link did it's job - very fortunate. That is why I asked originally what was the battery voltage at the alternator. There may not have been anything wrong with the battery and alternator you've already replaced. This may have happened during the removal or installation of your engine.
Here's a picture of the OEM alternator (+) cable with the loom removed. Notice the 8 gage fusible link. Now compare the 2 pictures...
Here's the wiring schematic that shows the 8 gage fusible link in the (+) alternator cable.
PS: when you make repairs - don't just arbitrarily replace the fusible link with a piece of 8 gage wire. Replace it with another 8 gage (not 6 gage, not 10 gage) fusible link wire to retain circuit protection. Another route would be to install a heavy duty in line fuse holder with 150 amp fuse if you're using a 130 amp alternator or 200 amp fuse if you're using a PA Performance 200 amp alternator.
Here's some suggestions:
BoostedGT480
Slow 3v
Montgomery, AL
exactly what it is..I replaced the battery because my previous battery was an acid battery in the trunk..replaced the alt because the pulley siezed up on the alt. so both pieces were needed...Looks like i will get the new wire ordered soon
