procharger f1
19COBRA93
Ford Racing
Clinton, Ut
Which F1? The F1A has the same size inlet (3.75") as all the smaller P1's, D1's, etc. The F1C has a 4" inlet. Jump on K&N's website and see if they have a short enough filter with the correct size flange.
The problem with the F1 blowers and a filter mounted directly to the blower is the transmission case on the blower itself is thicker than the p1/d1 blowers, so the compressor housing is closer to the shock tower. This leaves little to no room for a filter mounted directly to the blower. I tried it on mine and couldn't get anything to fit.
Twinscrewgt
Bad Smurf
Ogden, Utah
There's no way you will fit a filter on the blower. At least not one that won't restrict the hell out of it. I run a 12" filter on the street and a screen at the track
05mustang_TT_charged
Because Race Car!!
LSU Country
Uh wat? Ps is electric and I doubt the abs is costing much power lol
What? The Powersteering is ran off of a belt unless it is a 2011+ car and the ABS doesn't use anything but hydraulic pressure created by the brake pedal. It also uses relays to cycle the brake lines in the case of one wheel locking up.
05stroker
Never enough power guy!
Bullard Tx.
I was asking becouse if the car dosent have an ABS control unit or it has been relocated then the OP should look in my photo album !:ugh1:
fdjizm
Drag Queen
This guy is pushing 758wrhp with an F-1C and look at his filter...
http://www.mustang50magazine.com/featuredvehicles/m5lp_1107_2005_ford_mustang_gt/photo_08.html
http://www.mustang50magazine.com/featuredvehicles/m5lp_1107_2005_ford_mustang_gt/index.html
