Marc s
NASA AIX
Auburn, WA
I made my 1 piece driveshaft a two piece driveshaft. It appears that the M&H's worked better than I anticipated.
Brezick
Yinzer
Had a set of 3.73's lying around so decided to toss them in along with a trutrac diff.
JEWC_Motorsports
S197 Junkie
Marc, that just made me say wtf!!!! lol. Dude it sheered it right off. I was expecting something twisted, thats just crazy.
94tbird
4R70W FTMFW
put the new power steering pump in, only to find that the pulley wont sit flush, and the tool to push the pulley on breaks in the pump. new power steering pump then came out, FML lol
After seeing and hearing about all the things that can break at the track, I have made it a habit to always make sure I have enough cash on hand to pay for a tow truck to get the car home from the track if necessary.
Marc s
NASA AIX
Auburn, WA
This happened on the first pass. I was racing in a .500 pro tree class. I had the engine at 4500 RPM's on the two step, dropped the clutch and BANG. The car never moved out of the staging beams.
I sent the driveshaft builder pics. Ya gotta love AAA.
94tbird
4R70W FTMFW
AAA Plus is your friend lol
ive been towed home for free multiple times
JEWC_Motorsports
S197 Junkie
Marc, ive never seen a driveshaft sheer like that. Im curious to see that the builder says.
Ron, You broke the tool off in the pump? Damn dude you are the king of breaking shit.
94tbird
4R70W FTMFW
see my sig?
marc, holy shit, thats thin aluminum!!!!
gtcs07
Im just kinda here
New Jersey
I took everything i had kept from my CS and put it on the gt500 today. All the little dress up items
TurboPete
Miami, Fl
Ok long read but you get why Im upset.
Noticed a small fuel leak on my return line by the fire wall. Fuel line had a small pinhole. So I go to Lethals website just to make sure I bought the correct lines. On the website the kit says a -8 return line so I bought 20ft
of black xrp line, and 2 new hose end fittings a 90* and straight hose end -8.
I put the car on jack stands and got the damaged line off when I noticed the damn thing was a -6 return. I was shocked . I dont know why it was a -6, I must have never noticed it when I 1st got the kit . Then again I had probably the 1st kit from lethal so not sure if the kit was updated later .
Anyway that wasn't the big f*&^ up .
After getting everything finished up turned the key and the new hose was defected and had a pinhole in it leaking around the firewall again. I could see a small mist of fuel spraying.
WTF I was so pissed. Tomorrow Im going to have to cut and replace the section to the reg .
Pete
This is the one that was vibrating?
I pulled my front cover again. This is the third time since building this motor. I've had a small oil leak since day one. The block was used and the bonehead I bought it from cleaned the sealing surfaces with a power tool. This time I sealed all of the block mating surfaces with ultra grey. Verified squeeze out and did a retorque after 15 minutes. If this doesn't take care of it I'll probably start over with a big bore block.
