Nitrous guys
MindIfISmoke?
Wrecking Crew
Puyallup, WA
What are u running for spark plugs and what is your gap setup at?
My setup
Zex kit with 100 shot pills for starters
Zex window switch
Kb Bap
Also what do u have your window switches set to?
Thanks,
Matt
Sent from my DROIDX using Tapatalk
MOC826
I have a shitty program!
if you search a little, this topic has been covered quite a bit. but i guess a quick run down
spark plugs: ht0's gapped at .32-.34
not sure on the window switch but if you search you may be able to find something
3VPOWA
East Texas
I was running a 100-shot on FRPP one-step colder plugs, stock gap. Window switch set at 3200 - 6300 RPM, 6500 RPM rev limit shifting at 6200.
silverstang07
I ran 100 shot on stock plugs for a long time. Swapped out to ht0s. My stock plugs lasted alot longer and never had a problem running them.
It depends what year your car is. I have the newer designed heads, so I use brisk one step colder plugs. On the older style head (05-mid 08) the HT0 is the plug. I have my gap set at .032".
FWIW I ran a 100 shot on stock plugs, stock gap, stock fuel system, on a 93 motor tune and was fine. I wouldn't suggest it though, better safe than sorry.
Limetime
FRPP plugs 1 heat range colder, don't need a BAP for a 100shot
window switch 3k off at 6,500
bottle warmer of a nano system
TheKurgan
Florida Keys
I would set the window switch to kick off at 6000 - 6300. You don't want to hit the rev limiter when spraying nitrous. KABOOM. I'd set it at 6200 and shift at 6400.
You're right you don't need a BAP for a 100 shot though. I've datalogged many times and the fpdc never gets above 50%. Not for the Zex kit.
