Fuel Pressure Adapter Block Part #?
A John In NJ
Rice Cooker
NJ
Im looking for the part number from either jegs or Summit that will work with the s197... Thanks everyone!
-John
tmcolegr
It's All About the Build
Central, FL
Will the Zex 82035 fuel rail adapter work for you? Sorry I don't have the Jeg's or Summitt part number
don_w
Dyno Numbers - Who Cares?
San Diego, CA
I'm not sure if there is something new out there for the KBs now, but not too long ago you had to make a minor mod to make it work. I used a dremel to notch the area shown below in order to get the sending unit in there.
The following pics are courtesy of PMP...
94tbird
4R70W FTMFW
john the kb already has an adapter for fuel pressure as don showed above. you jsut need to cut away a little material on their flie adapter in the pic Don howed
don_w
San Diego, CA
RPM outlet sells one too.
http://rpmoutlet.com/05gtfuel.htm
Yeah, Yeah, I know everyone hates RPM outlet.
I originally tried on of the Motoblue adapters from RPMoutlet, and it didn't fit with the KB.
Is that designed to work with the Kenne Bell S/C?
+1... works great. No need to buy anything else.
Born To Run
Woodstock,Ontario
adaptor
I just ground off some of the shoulder on the 1/8 NPT male adaptor,there is lots of meat on it.
BACNBLAK
Old and Wise(guy)
Charlotte, NC
I had this RPM Outlet adapter (blue block above rear of fuel rail) on my car with a KB 2.6H for 18 months, just took it off the other day. I'll sell it to you cheap, PM me if interested. Here's a shot of my new setup, it'll be finished this weekend.
BACNBLAK
Old and Wise(guy)
Charlotte, NC
Fuel Pressure Gauge Adapters
LOL... its been gone for a couple years already.
So I'm looking at my stock fuel rails yesterday and discovered the dummy who installed my KB originally, had STACKED my Motoblue gauge adapter and KB adapter one on top of the other on the driver's side rail! I no longer need either one, so PM me if interested. I'll even Dremel out the corner of the KB adapter if you like.
