GoFaster06
- Joined
- Jun 26, 2010
- Posts
- 225
- Reaction score
- 1
Do u have these 2 mods? How much & where did u purchase pump from?Circulates more coolant through the H/E and helps dissipate the heat generated by the l/C.
Yes have had both for quite some time now.
prior to the Afco Pro-Series Dual Pass Heat Exchanger being available I purchased the Afco dual pass heat exchanger and added dual Spal fans. The Meziere I/C pump I purchased from Summit. I also have a Canton battery box mounted I/C reservoir
Current & Afco H/E are air to water, so I'm guessing a water pump is the same as an intercooler pump?
Current Thinking I might get this one in the future-
[URL]http://www.lethalperformance.com/05-09-mustang-gt-cooling-water-pumps-c-576_1140_2127/meziere-05-2010-mustang-4-6l-heavy-duty-water-pump-sapp-s-p-34836[/URL]
No the I/C pump is not the same as the water pump for the engine coolant
Yes - however it's much cheaper at Summit.
You do realize this isn't the water pump for the I/C coolant??
