squidzx6
hid
fine fine if you want ill swap you my stock headlight halogens
Thanks for all of the help!
I still need to clarify a few things about downgrading my HIDs to Halogens because I'm pretty new to this...
I'll probably need new 3 wire plugs, but is there anything else I might need?
Is it just a matter of taking the solenoid wire from the HID harness and attaching it to the high beam wire on the halogen pigtail, igniter wire to the low on the halogens and then ground to ground?
Am I understanding everything correctly?
What happens to the 4th wire on the hid harness? Just tape it down?
I'd really appreciate any help or advise!
Thank you.
