Hey Ken what tires will be using for the Texas Mile. What Rims.
Pete
I'm already registered. I'm Number 50!
Street Legal of course and we will be legal to 215 so I'm going to shoot for 214.9
Main goal is over 200. But if nothing goes wrong that shouldn't a problem. But every MPH over that is tough. So I'll just be happy breaking 200. But I won't be satisfied unless it goes 210+.
It was mentioned that there's a broken patch of road somewhere 1/2 a mile down the track, nothing major but enough to trigger the car's traction control and cutting a bit of power for top end speed. Not sure how much truth there was to the lost of power in that statement but this might be something interesting to look into considering your goal.
Exactly and I remember speaking to you about this at the October meetThere is a transition that was pretty rough about 1/4 mile out. They were actually working on it some more during the October event because it was so bad. There's a lot of good things about the new Beeville location, but the surface isn't one of them, Goliad was a lot smoother, it's too bad the Navy wanted it back.
If only they would allow people to used that newly paved partwhen i did my final run sunday of the oct event they had fixed the bump mostly, it was at about the 1000ft mark if i remember correctlyThere is a transition that was pretty rough about 1/4 mile out. They were actually working on it some more during the October event because it was so bad. There's a lot of good things about the new Beeville location, but the surface isn't one of them, Goliad was a lot smoother, it's too bad the Navy wanted it back.
Hey are your front o2s before or after the turbo, and whats the .ar on the exhaust side.
I think Hellion copied your kit lol
I dont mean exactly but you were the first and then all of a sudden hellion has top mount it twins
Your definatly doing it right, great job man
And that leads to my next question
I know beefcake had issues with o2 extenders
Did you have to use any?
And did you have to extend anything to relocate the pcm?
Ken def get one of those cams strapped down on the roll bar filming you on the mile. I bet that is going to be a blast. HOpe the brakes are in good shape!
Our kit doesn't need extensions. The 02s are very close to the factory location.
And there are no wires to extend to move the PCM. The factory harness has enough slack.
I did forget to mention that we are putting some brembos on the front also.
I have the helmet cam that I can now put on the bar. And I think I'm going to pick up another Contour Roam. I really prefer the Contour over the GoPros.
What do you like about the contours better? How's the sound quality compared to GoPros?
Sounds awesome!!! I saw you guys run out at SGMP! Hoping to have my car at the next mile event. Best of luck to you and the kit is beautiful!
Ken, are you going to be driving the car at the mile?
Pretty much everything. I like the lipstick form factor, I like the quick slide on top. You always know for sure if you are recording or not.
I like that it has bluetooth built in and I can stream right to my phone so I can make sure the camera is lined up. To me it's just a better built piece overall.
Never was a fan of the go pro plastic box. The Contour just seems to be a nicer piece. Also has an HDMI port built in.
Thanks but we weren't at SGMP.
Wow... I just realized I think that was the Hellion car. Sorry about that... either way your kit is much cleaner in appearance and the performance definitely says it all! Great job!
If it was Ken, you would see him running it down the track, not parked beside it all weekend....lol
