how much boost on stock 3v
05ghost
rockwall
How much boost will a stock 3v 4.6 hold safely? Not looking for high horsepower or torque Numbers, just. Want good power for my daily till I can build forged shortblock ? Thanks guys
Commonly accepted numbers are about 450-500 with some caution and a little bit of luck.
HEMI LOL
The Feast and The Famine
Fircrest, WA
don't let these guys fool. you. the stock rods are safe to 650whp. id get a T88 and turn it up to 18psi. just adjust the sct tuner yourself. no need to even dyno tune it. you can probably even run 87 octane too.
cwhit23
Really ???
GT33
Bent a rod at 7lbs. On any motor built or not can break. On my built motor i dropped a valve and destroued the block. my 2 cents.....
matt06
St. Louis
The key is to also make sure your running enough boost. Between 6-7 pounds and your guaranteed to be safe. Going under 6 or over 7 and it WILL come apart. 6.5 pounds is obviously ideal......
Wlkn Tal
St Augustine FLA
THe motors are only built and engineered for 300bhp..., however I run 10lbs, with a safe tune, but I don't beat the shit out of every time I get in it either, I also understand it could go at anytime. If you are going to modify your car you better have a backup plan. I've heard 7 or 8 is idea, but still not guaranteed.
