Airborne2000
- Joined
- Jun 21, 2009
- Posts
- 994
- Reaction score
- 7
I keep running into a weird problem. About 2 weeks ago, went out with the GF and parked my car at her place, a few hours later I went to go start the car and all power was good but the car wouldn’t crank, I could hear a clicking the fuse panel in the car but nothing happened, all lights worked and still getting 12+ volts on battery. “check charging system” displayed on panel. Checked all associated fuses (inside and under hood) and all good, so the next day I came back, tried again and still nothing, the next day, I tried again and it started right up. No issues for 2 weeks, then 2 days ago I parked at walmart came out tried to start and the same problem happened. I checked fuses, I noticed 2 things, 1. The radio would not make noise when the car was in park (not running) but in all the other gears it would start playing, 2. When I hooked my sct 3 up to it and turned the key to the ON position the car would shut the tuner off immediately. I then opened the fuse box under the hood, looked at it then tried starting the car again and it started right up. No issues since either.
I took all the starter fuses out and hit them on the wire wheel just in case and everything seems fine now. checked all wiring too incase something was loose but everything is nice and tight.
Can this all be a symptom of the chip in the key not being good anymore?
I don’t think the alt or starter is bad, it seems electrical not mechanical.
Any ideas??
Any ideas??
