don_w
Dyno Numbers - Who Cares?
OK, here are the symptoms. When cruising down the highway, say 65mph, and I give it just a little pedal (like passing, changing lanes, etc), the car lurches to the side. Usually it pushes the front to the right (or rear goes to the left), but every so often it does the opposite. And under full throttle or at lower speeds, I don't ususally feel it doing it.
At first, we thought it was the M&H drag radials. They were 3 years old and pretty used up. So I bought new ones. No change in the wiggly ass. In fact, it now seems to get a little worse each day. It's getting to the point where it is downright scary at times. I really need to figure out what's going on before I put this thing into a K-rail.
I'm hoping to get it up on jackstands this weekend and take a close look at the suspension parts. Maybe there is something loose. But, I don't hear any unusual noises at all.
If it isn't the suspension, could it be the Detroit Locker? It has the typical "clunk" of a locker, but could the unlock/lock process get that severe such that it moves the whole car sideways? And would it get worse over time?
Finally... what else could be causing it? Any and all thoughts appreciated...
FYI... This is my set up:
REAR END
FRPP 4.10 Gears, 8.8”
Detroit Locker Differential
Powerhouse Aluminum Driveshaft
BMR Driveshaft Loop
Moser 31-spline Axles, 3” Studs
Moser Rear End Girdle
SUSPENSION Ford Cobra Jet Rear Springs
BMR Tubular K-member
BMR Radiator Support/Sway Bar Delete
BMR Adjustable Lower Control Arms
BMR Adjustable Panhard Rod
BMR Panhard Relocation Bracket
BMR Adjustable Upper Control Arm
BMR Extreme Anti-Roll Bar
Steeda Lower Control Arm Relocation Brackets
Spohn Rear UCA Housing Bushing Kit
Calvert Shocks
REAR END
BMR Driveshaft Loop
Calvert Shocks
