SCT Livewire AFR question
Franchi
Senior JR Member....
In a house, with a mouse
So I know the SCT Livewire can monitor AFR, but I'm assuming it would need a wideband sensor welded into a bung on the exhaust to do so like a normal wideband? Or can it detect that from the OBII port alone? I would think it would need a sensor but I couldn't find any info on it on the SCT site....
702GT
S197 Fanatic
Las Vegas
I tried setting up the Livewire for AFR, it was too much of a pain in the ass. After I made the proper firewire harness, the livewire needed a specific AFR formula to display properly. I talked to my tuner, posted here, and called SCT, couldnt get a formula for it. The guage looks better anyway...
TheKurgan
Florida Keys
You need a sensor and a "brain" such as the LC1. I've had my LC1 for about 4 years now and it still works great with my Livewire. The Livewire has the correct formula built in for the LC1. All you have to do is select it.
crownaviation
http://www.tudyno.com/
Broke dafuk down
Have not got this far with my autometer phantom. I do have a peak recall function hooked through a wot/window switch to make that work on the gauge. I am interested I datalogging my afr via livewire too...
Anyone with a phantom wideband doing that? Sorry for the hijack op.. but have similar question
05stroker
Never enough power guy!
Bullard Tx.
Here is the analog equation I use on my Autometer 4378 WB
0.06803*(10+1.5*v)
Hawgman
THE fucking bad guy
With my Dynojet Wide Band Commander, you use 0.068306*(10+1.6*v) in the analog1 equation
08stang
Madison, Indiana
sweet i have a innovate af gauge with the LC1 havent tried to hook it up yet but was wondering how hard / easy it would be
