Good to know. Did you machine your spare cap?
No. It worked. I did remove a small amount of material with polishing compound (flitz metal polish) and a socket. IIRC it was a 3/4 socket that fit the radius of the cap almost perfectly. I had to smooth some radial scratches that were in the scrap cap.
Others have had caps line up. Like I said in an earlier post Ford has a very consistant process for reaming the cam bores.
You will have to take this one step at a time. First try the weld. If the welder screws up then go to the cap swap. If the cap doesn't line up then you are talking about taking the head off and having it reamed. The bad part about that is if it's off enough to need an alignment the chances are that the bore will end up with excessive clearance. At that point you are hosed and need a new head.
