So, I am ditching the Mod Camponents adjustable gears for the Livernois lockouts as I am not comfortable with the amount of oil coming out of the adjustable gears during pre-lube. Were the Livernois available when I bought the Mod Camponents, I would have gone that way in the first place... Keep it simple...
So, now I am re-assembling the stock phasers - thought I'd share the fun and put some pictures of the process... Some of the intermediate steps apply to the "normal" install of the Livernois lockouts...
First some disclaimers:
1. Don't try this at home - keep in mind I am not expecting full functional phasers out of this as they are locked out in the end. I would hate for someone to try and use this info for evil (aka blowing up your engine with just enough info to get you in trouble - leave that to me... )
2. Ford does not treat these things as serviceable parts - any misalignment in the timing trigger wheel calls for disposal, NOT repair.
3. If installing the Livernois lockouts - DO NOT remove the bolt holding the clock spring - you don't need to - leave that one in (you'll see in the pictures)...
4. I repeat - you DO NOT NEED TO DISASSEMBLE THE PHASER TO INSTALL THE LOCKOUTS!
I had disassembled brand new phasers to build the Mod Camponents setup (see Biggus Buildus Maxiumus thread), fortunately, I kept all the parts and notes to put them back together (not sure why at the time, but as it turns out, a good idea
Pictures and comments to follow...
)Pictures and comments to follow...
