Mikes a nice guy and I'm not knocking him in anyway, just reporting what's been done so far and the results.
Thanks again Mike and I'm sure we'll get this resolved soon.
Ended up getting lift time last night over my buddies.
- Put her in the air and drove her on the lift
(do not try this at home we're what you call, professionals kids) and was easily able to reproduce the ticking sound. Figured it had to be the rears. So per Mike's suggestion we swapped out the Hawk pads with the OEM's we took off. Put her back together and drove her on the lift again.. Ticking was still there.
- Then Mike suggested it was the rotors. So we put the rear back to 100% stock.
Ticking was gone! ...figured it has a bad batch of rotors and that was that.
- drove home and the ticking is still there.. only thing left is the front rotors. I'm not taking the Brembo's back off and putting the stock crap back on to test that.. so called Mike as I was gettting ready to head home. I believe he's going to send me a different set / brand of rotors, but I'm waiting on a call from him this morning.
Check your PMs... I have a solution
Not the solution, I did the bedding procedure off Hawks site twice. Once after the initial install on the 4th, then again after we uninstalled / reinstalled the brakes on the 9th. Didn't bother the last night after we uninstalled / reinstalled / uninstalled / reinstalled OEM for the rears sense it didn't make any sense to do so. Thanks for the suggestion though.
