toorbeenee
turbine lunatic
+1Easy boys, easy!! Lets take our time and get everything dialed in and then is time to bang the bottom out of the forged parts!
take your time and enjoy the car, congrats buddy
Now go bang the wife!
Already on it!!!
I wanted to throw an updated mod list out there for everyone that is fallowing. I threw this together just now.
Engine
Livernois 3V 298 Stroker
9:1 Compression
05+ Aluminum Block
Custom Livernois Forged Steel Stroker Crankshaft
Livernois Exclusive Diamond Forged (2618) Pro-Series Pistons
Diamond Rings, Locks, and Wrist Pins
Manley H-Beam w/ ARP 2000 Bolts
Clevite Tri-Armor Coated Bearings
Full ARP Hardware (Head Studs, Main Studs, Rod Bolts)
Stock heads/cams
Arp head studs
Cometic gaskets*
Trick flow springs
Livernois Vct lockouts
JPC cast intake manifold
Stock TB
Autolite HT-0 Plugs gapped at .30
Ram power grip hd clutch
MGW STS.
Fuel System
Fore precision billet hat (Triple pump)
Twin Walbro 405lph Pumps
Fore Regulator
Fore Y Block
Fore 10 mic filter
-8 an feed
-8 an return
SD 80#ers
Aeromotive rails
Power Adder
76mm cast wheel ceramic bb Turbo
.80 cold side .96 hot side
Full 3" cold side
On3 hot side
50mm Precision BOV
46mm Precision Wastegate 10.5PSI spring
Suspension/ Wheels and Tires
FRPP K Springs
BMR Panhard Bar
BMR Sway bar relocation brackets
BMR Double adjustable LCA's
UPR Front radiator support/ sway bar delete
20x9 CS67 Toyo Proxis 4 255/35/20
20x11 CS67 Toyo Proxis 4 295/30/20
15x10 DarkStars 28x12.50 MT ET Street Radials
Electronics
AEM TRU BOOST
AEM FUEL PRESSURE
AEM WIDEBAND
N2MB WOT BOX
Happy for you brother!
