I've got a brand-new Fays2 Watts Link sitting in my garage that I haven't had a chance to install yet. I'm planning on bolting it on in a couple weeks. I've got a couple questions first, though.
1. How do you center the rear axle while installing the linkage, and how do you keep it centered?
2. The vehicle suspension must be loaded during the installation, correct?
3. Are there any issues with driving a Watts-link-equipped car as a daily driver and on rough roads? (My car is driven ~10,000 miles a year.)
4. How far from the differential do you install the clamps that go on the axle? (2010s and earlier have axle vent tubes that the Watts link lines up on; the 2011+ has these tubes in a different location.)
5. I've got 3" Magnaflow over-axle pipes. Will the Watts linkage hit these?
Thanks in advnace!
1.) Before you lock down the axle clamps, have a buddy take a tape measure and measure from the inside of the wheel well to one of the tread grooves and then do the same on the other side. It wont matter if the rear axle is in the air or not because there is no suspension arc in the Watts Link geometry so it can be done in the air. If you need to move it over you have to move the axle clamps on both sides of the axle to move it over. DO NOT use horizontal arms to move the axle as that messes with the Watts link geometry.
2.) I did mine in the air or off the car. Most of the bolts on the propeller are impossible to install with it on the car because you can't fit a torque wrench with a socket between the differential and the propeller to tighten it down and you can't fit a combination wrench on the other end to hold it in place. The center pivot bolt is the exception to that, I did it while the frame was on the car. So what I did was assemble the center pivot assembly on the ground. This requires you to have the arms for the watts link at the necessary length and may require some pre-fitting to decide how long they need to be. Jim says the watts propeller should have the top part pointed at about 1-o'clock with the arms in the horizontal position. The limiting factor is going to be the axle vent. There is a lot of adjustment in the axle clamp but it will still limit how far outboard the watts link will go. There will be a lot of test fitting done before bolts get tightened down.
3.) Well, not really no. It will make things more prone to coming apart if you mess up and have to reuse a nylok nut and forget loctite. I noticed that when you tighten the center pivot bolt to 100 lb*ft that it also cracks the powder coating on the frame and if you adjust the height of the center pivot a lot you can get squeaks from that area. As for noise, my Fays2 is 100% silent with the exception of the squeak. I can't even confirm it's the Watts link, I just have a sneaking suspicion it is. Unlike my Rod Ended endlinks (Strano/UMI competition endlinks) which make this dull thudding noises over every little bump, the rod ends on the Fays2 are quiet. Don't forget to install the O-rings!
4.) See 1.)
5.) The frame on the Fays2, at its tallest point, is no higher than the PHB support brace. So if you don't have issues with it hitting now, you shouldn't with the Fays2. That said, when I first installed my Fays2, the driver side axle clamp was rotated too far up and on severe bumps it would hit the exhaust pipe. I rotated it down and out of the way and rotated the axle clamp the correct amount up to keep the arms at equal but opposite angles and all is well again!
If you end up doing the install with the suspension still loaded, make sure that when you do the watts link final adjustment of the axle clamps that the front is at the same height and the car sits level because any rake at all will not give you an accurate enough load to get the bars horizontal at ride height.
7.) Prepare to enjoy a brand new car! The difference between the PHB arrangement and the Watts link can be felt when you drive the car, even daily, and is absolutely amazing when the car is pushed to the limits. You may not have this "problem", but I do, and that is being able to literally at the Apex of a corner just mash the gas pedal and the car will plant all the power to the ground and go. I'm not making 412 HP/390 lb*ft of torque stock though either!
8.) What happened to 6.) ??????
Picture of my install:
And video after it's all done:
http://www.youtube.com/watch?v=uFi9Ck5anf0
