Not as much as a blown motor due to bad tuning.
Say what? U messed the motor up?
No, I believe that was a shot a blackgt in regards to his motor incident.
Did the tabs on the bumper get rip? Or is it the clip panel the screws to the body that is damaged? When i was a kid, guys would cut the key off wile driving and then turn it back to run . It would cause huge back fire and scare people. It would al so blow up the mufflers just like yours.
as shitty of them as it is, I knew this is what they would do to you.
As much as I feel bad for you, Warranty's cover defects in material and,or workmanship, and it is clear that you mufflers (both) suffered from explosion, most likely from raw gas, or fuel vapor. That is not the responsibility of the manufacture. Sorry. At least you got another set of mufflers.
He was offered another set of mufflers as warranty, he declined, I don't see any problem here.
It's obvious it was a backfire of some sort, and no, that isn't a seem that it busted at. Exhaust can generate around 20 psi for 1k hp, these mufflers were tested to 600 psi.
You should have taken the replacement mufflers. That's more than what I expected them to do.
I really don't see this as MBRP's fault. WOT box causes the welds to be weakened and the buildup of exhaust backpressure from using a chambered muffler in a FI configuration caused additional fatigue till the seam came apart.
Looking at cutaways of other mufflers, the MBRP isn't any thinner material than any others I am finding.
So Summit tried to get money back from you when MBRP denied the warranty?
I've all but completely stopped selling parts because I would always get stuck in Summits position. I wouldn't expect the customer to pay after I accepted it back. And it happens too often.
