I run DTC-70/60-f/r. I have the BAER 6 piston big brake kit that comes with the Super Snake. My car eats the BAER calipers. It is my biggest track expense by far. I get 6-8 track days out of a set of front rotors and another 4 out of the rears. My car weighs in at 3900 lbs and makes 700rwhp. At VIR I am over 160mph at the end of both the front and back straights. So my system is working pretty hard. I use the Brembo 600 brake fluid and don't have any pedal problems.
I very much agree and want to emphasize a few things said here.
1st, you have to change the pads at about half thickness. Not only does their ability to be a heat sink diminish, but the rate of wear goes up as they get hotter and it becomes self sustaining. With as heavy as our cars are, once you start running with the faster run groups, pads are only going to last 1-2 events on the faster tracks.
2. You need to run full 4 inch brake ducts. Not the 3 inch opening that you have. That area where your opening is can be cut out and screened in and still look very nice. I had a similar setup with my car, as it came back from Shelby that way. It had a 3 inch hose that had an expanding piece that went to 4 inches. I cut bigger holes and ran 4 inch holes the full length. It made a difference in my pedal. It is rock solid for 30 minutes now, where before it never went away, just started to get a little squishy.
3. Again with the weight and speed potential of our cars, for tracking purposes, you need a bigger heat sink. 14" rotors minimum. Any 14" kit you purchase will be an upgrade and will fit in the 18" GT500 wheels. My 14 inches with huge 6 piston calipers fit mine until I got something else. It was tight, but they fit and didn't rub. I had one problem where a balancing weight rubbed a caliper. I had the weight move inside a little and it was fine. So be sure to check that every time you get tires and a new balance job. I tell the tire mounter if he is putting weight on the outer edge, he has to move it in to clear my calipers.
Lastly, don't skimp in this area. The biggest HPDE crashes I have seen over the years have been brake failure related. As you get faster, the time in between braking goes down, so the brakes have less time to cool. You are using them harder because you terminal velocity is higher and as your skill level & confidence get better, you brake later and harder. All of this and your car didn't get any lighter and you may have added R compound tires to make matters even worse.
So of course the brakes are going to give up and they are going to talk to you, you are going to say "I only have 10 minutes left in the session....I can make it", and at the end of the back straight the pedal goes to the floor and although you are a better driver now, your not ready for this situation. Hopefully no one is in front of you and you just tear your car up and don't get hurt. Or better yet, there is a large run off area and you don't hurt anything.
Invest in the best braking equipment you can afford. Do it over motor, suspension and tires 1st
Bill
