Need part numbers
b00stedgt
New York
Does anyone know the part numbers for the motorcraft rear main seal, slinger, and housing? Are the bolts one time use only or should I replace those as well. Parts are going on a JDM 302E
19COBRA93
Ford Racing
Clinton, Ut
Yes the bolts are torque to yield and should be replaced. Here are your Ford part numbers:
Rear main seal: F4AZ-6701-A
Slinger: F65Z-6310-A
Housing: 6L3Z-6K301-AA
Bolts: N806155-S437
b00stedgt
New York
Do you know the special tools needed to install? I know it can be done without them but I would prefer to use the correct tools
tmcolegr
It's All About the Build
Central, FL
Bolts: N806155-S437
I've never seen anything stating the bolts that retain the housing are torque to yeild. Where did you find that information?
19COBRA93
Ford Racing
Clinton, Ut
I'll have to check the torque specs for the 3V. I know they're torque to yield on the coyotes, so I assumed they're the same way on the 3V.
