SoundGuyDave
This Space For Rent
- Joined
- Apr 9, 2007
- Posts
- 1,978
- Reaction score
- 29
that is one technique, braking late and deep into the corner, past the turning pint can be used if to gain traction when your brakes are up to it. This will get you a faster entry speed and more cornering grip.
Not exactly. You're talking about trail-braking. Yes, it will gain you entry speed, however it will NOT gain you cornering grip. Basic "friction circle" theory tells us that we have finite mechanical/aero grip. We can use 100% of it for braking, or for cornering. When you do both, however, the sum of the forces cannot exceed 100%, thus any braking will REDUCE the net amount of grip available for cornering. TANSTAAFL. The way trail-braking provides gains is in the margins. A smooth corner entry doesn't suddenly transition to grip limit laterally, it does it over a finite amount of time, and during that time, you are applying less than 100% of the available grip to cornering. Trail-braking uses that marginal unused grip for additional braking, past the turn-in point, in exactly the same way that you start accelerating on corner-exit before the wheel is completely straight. A wee bit too much braking after turn-in, and your rear end starts to come around, though, since at that point, you've exceeded the total tractive capacity of the tires. Done judiciously, using the brakes to initiate rotation, then catching it with the gas pedal to maintain attitude, can and will allow you to increase your exit speed, however the point still remains that you only have so much grip available for cornering, and that WILL determine your mid-corner maximum speed.
Please note that this technique is seriously advanced-level, and cuts the margin for error right to the bone. A slight reduction in grip (sand/leaves/spit on the track, tires starting to "grease up") will cause you to either understeer past your apex or transition to oversteer too quickly. The first will result in a 2-off or 4-off situation, the second in a spin.
Done properly, trailbraking will result in the net fastest time through a corner. Roughly 90% of the braking is done in a straight line, with consistent force, then the remaining 10% (-ish) is done from turn-in to apex, with braking force being reduced at EXACTLY the same rate that cornering force is increased while the car takes a set, and rotation is begun. At the apex point, you will be at maximum lateral load, and no other forces can be applied. As soon as you pass apex, however, and start to open the wheel back up, you can then start to apply forward acceleration. The net effect is that there is a VERY brief (1/4 second?) period of time when the car is in pure cornering mode, but the rest of the time through the corner you're also either braking or accelerating. This does NOT work will with classic late-apex lines, you'll have to be running more of a geometric line (earlier apex).
In sum: Geometric line reduces your margin for error but increases speed at apex. Trail-braking on entry reduces your margin for error, but increases speed at entry. You can shave a few thousandths of a second per corner by doing this, but WHEN (not if) you bobble, it will cost you tenths of a second or more.
I'm not saying that you can't do it, but you need to think of when it's appropriate, and you need to be a VERY consistent driver before trying this on any sort of routine basis. If you're not clicking off lap times within a few tenths for an entire session, then you don't have the precision necessary to successfully execute this with a predictable outcome. Small changes (>3mph and 2-3' at turn-in, 1' at apex, 5% variation in braking pressure for example) can seriously impact the traction requirements for a given corner. Because you're operating right at the limit, it's difficult or impossible to recover from a bobble gracefully.
