would you interested in selling the faux leather door panel inserts?
I was wondering if the steering wheel is still available (I went thru the responses but I only saw a pm sent about it)
Also, are the two plastic support brackets that the front fascia bolts to available and in good condition? (The verticals of the front fascia on either side of the grille would screw into these brackets)
Yes, let me get a good look at them to make sure they're in good shape.
How about the black plastic trim around the driver/passenger windows?
Those trim pieces are perfect. I'll do $50 shipped for the pair (it's going to be kind of a large box).Yeah, on the outside.
Is it the low fluid sensor in the reservoir you're after? That can be had new from Ford for about $20.How much would you do for the master cylinder assembly? The sensor went bad on mine
did you have a chance to check on those leather door panel inserts?
carpet still available? sent PM
my stealership quoted me about 400, said I needed a new pigtail connector, and that the sensor could only be bought as a package....psh thanks for letting me know its only $20...I am glad my instincts told me not to buy it
Just a follow up: Did the sale on the seat belt reach extenders go through?
Thanks
