Marc S build version 6.0
808muscle
Maui
That is gonna be one loud muthafucka...............very cool!!
Wicked97
Beltsville, MD
Fuel tank sump.
What are you doing with the sump? Are you still running a stock tank in this car? Are you going to do two sumps?
You can Run a high PSI pump with a carb if you have the right regulator or run two? Thats how i set up my car when i was messing with a carb after EFI.
Marc s
NASA AIX
Auburn, WA
And the cell didnt have a sump already?
Cool Thanks
I built a cell last year that would accept the stock fuel hat. Now that I am going with a carb, I will use the original fuel hat for the fuel sending unit and weld the sump to the bottom. I will be running the Nascar mechanical fuel pump that came with the engine and run a -8 line from the pump to the tank.
Marc s
NASA AIX
Auburn, WA
I had a custom solid roller cam ground by Crane and it should be here next week. The lift is .741/.798 and the duration is 270/280 at .050 with a LSA of 106.
The BMR K member arrived today and is installed.
Marc s
NASA AIX
Auburn, WA
Wow, that's some insane lift your running.
The heads don't stop flowing until .900 lift. I didn't want to go too crazy with the cam events because I also need some level of durability. With the cam I had ground, I will still have to change valve springs twice a year because the valve timing events are really fast on the intake.
Mike K
WANNA BE FAST
Richfield, MN
Shit just got even more real. I can't wait to see picks and vids of your car when its done.
