FS: 302 3v Stroker
chutoyy
Seattle-ish, WA
Was in the middle of building a 302 stroker engine using the kit from Brenspeed before my car blew up... Engine still needs some work and components (timing, sensors, freeze plugs, etc...)
It has this kit, http://www.brenspeed.com/b302-ra2.html and ARP studs.
I'm just looking to try and cover the cost of the stroker kit and engine block cost... Asking $3500 shipped freight OBO/ $3000 picked up in OC.
Turning it over by hand... The knocking noise is NOT coming from the block.
https://www.facebook.com/v/10150717848563173
Blue Vue
I would be all over this.... if a torque plate were used during machining...
GL with the sale.... BUMP!
chutoyy
Seattle-ish, WA
It's the Holidays, I want this gone before the New Year... make an offer!
Rotating assembly wasn't touched, just installed... Block can be sleeved.
JoshK
Modder AKA Fuel
Nebraska
Already offered that much and asked a bunch of questions about bearing clearances and tq specs with no answer
Makdaddy
I am Dysfunctional
South of Chicago
Well I need an engine like I need a whole in my head
But I could start to get a block and a set of heads ready for the future
If the price is right
JoshK
Modder AKA Fuel
Nebraska
Need to find the spec sheets... in the pile of mustang shit I have.
Sorry, just calling it like I see it. It was Sunday when I asked for those specs. Not gonna pay big money on an engine that I don't know the specs, esp when it comes with 4032 pistons.
Here are the questions that anyone interested will probably want to know.
What is the piston to bore clearance?
What were the rings gapped at and what kind of rings are they?
What are the bearing clearances and what kind of bearings were used?
What tq values were used?
What assembly lube was used?
What rod bolts are they? Do you have a closer pic of the rod bolts and the crankshaft verifying it is a kellog?
Can you send copies of the receipts?
What finish on the cylinder walls and head deck?
How many pieces of mallory metal were needed to balance it out?
2mchtoy
addicted to speed
Montezuma,IA
Seriously, if he would sell it for 2k. That is a great deal! Think of how much a stroker kit costs, then even add the cost of an aluminum block. Then machine work. I know personally how much it costs and your well into over 3k. Glws
