The Devils Reject
Deez-67
Edmond, Oklahoma
This thing is coming along great... I'm ready to see some video of this girl moving!! or some #'s
BMR Tech
Traction Vendor
Tampa, FL
Don't weld on those pretty brackets man...
Looking good! All the BMR stuff fit good?
TexasKyle
D.I.L.L.I.G.A.F
Katy, Tx
Not that they aren't great brackets BMR, because I am sure they are. BUT, there have been threads on this very board where members have had the brackets bend and allow one wheel to smash into the fender due to rearend shifting. It can happen, so better safe than sorry. Weld those things up giz. You are going to have some serious HP when it's all said and done.
gizmo5
Italian between my legs
Went to go clean out my catch can and this is the awesomeness it filled up with...
Some say run them, some say they don't do a thing... But keeping this OUT of my engine is enough for me to keep it on there.
I also went from running it with vacuum, to running to the atmospher, and have switched again to both lines going to the CC with one line going to the intake tube to keep vacuum in the top of my motor.
Also, I cleaned the media in the CC as well and decided to put a small amount of fluffed up steel wool in the main body. I think that will aid in it's function even more than it does now.
Kenaizer
Denver
Damn that's milky.
Do you have a check valve keeping the pressure from behind the throttle body from getting into the CC?
UltraKla$$ic
PERENNIAL WAXXER
Louisiana
Thinking of all that going into the manifold/throttle body makes me cringe! I checked mine after seeing all these CC full of puke and mine was spotless. Guess I need to actually start the car to make it puke eh? :chairfall: LOL!
gizmo5
I have the vac nipple behind the TB plugged with a vacuum cap. The only vacuum the CC now is the intake tubes nipple on the bottom. That way there is absolutely no chance of a vac leak after the MAF air. Its all on the suck side, lol
When I checked the intake hoses they were clean as a whistle which tells me the moroso CC is doin work! lol
Kenaizer
Denver
Haha I was thinking it wasn't necessary on your car when you posted that thread but to each his own. Better to err on the side of caution.
gizmo5
Driving would help induce it... lol
Remember too, I have springs in my lines to keep them solid and from sucking closed. I think this also causes the "vapor gases" to slow down and collect in a more solid state. Shits all science like and stuff..... :beerdrink:
Kenaizer
Denver
Good thinking Bill Nye! Maybe I should do a setup like that...
As long as your oil cap and dipstick aren't milky I'm going to stop worrying about your car and go back to waiting for forever for some damn videos!
konablue11gt
Evansville IN
Yes Bill where the fuck are these videos you keep talkin bout?
gizmo5
Im gettin there... lol :beerdrink:
About to go do some WOT to 6K logs right now, and as for my oil on the dip stick, its all normal amsoil like. haha I checked it right away when I say the CC nastiness
