Kaboom
05stroker
Never enough power guy!
Bullard Tx.
I disagree with your last statement. Yes, Shaun had no problem starting from scratch, but there was no point. It's not like the Lund tune was bad, it was just unfinished/needed tweaked and I did not have the time to start over after being blown off for quite some time.
If anything all Shaun was doing as trying to resolve a bad situation, you can't fault him for that.
I will agree it was a bad situation that you and Shaun where put in with the LR camp here and I don't fault him (Shaun) at all. Just wish he would have done it all his self and there wouldn't be this issue now. I understand that if you pay for something it should get finished, that is Lunds fault. Bad deal all around IMO. Good luck though.
So who will tune the new motor?
Seer
I'm keeping the new tuner under wraps. It is not AED though, as they stated they lack the provisions to convert the fuel system type to return with the new 2011+.
Reason being is, it may have some hiccups at first and I'd like to let them sort those out before saying who it was. I'm very patient with tuners and a know a lot of what goes into their process of calibrating a vehicle.
But just as little glimpse into what I am hoping to accomplish. Essentially 24psi on E85, so hoping to put down over 900 to the ground.
05stroker
Bullard Tx.
I can accept that, good luck and I look forward to the update.
This is going to be good. You are doing this with the 2.9?
Seer
You should be able to do it. It's just a guess on my part though. This will be fun to follow.
I thought about doing the 4.0, but I'm running low compression, and most likely stock cams. I believe after reviewing its compressor maps, the 4.0 doesn't seem to wake up until about 25-26psi. Great for a track only car, but I don't think its a good street blower for my needs.
4.0 makes power at lower boost levels.
Mine at 24# made 967 on a DJ. Now at 20-21 made 775 on a MD and a bit less timing.
white05gt
Illinois
I'm guessing it won't be Lund:thud:
Seer
Compare compressor maps. It's great if you have a higher comp motor at lower boost. My motor is low comp
VTXFrank
Obama SUCKS!
Santa Rosa Beach, FL
I've not been on the site much lately and didn't know you had a blown motor. Sorry to hear about that brother! Hopefully, your new motor will hold for what you have planned for it.
What are you gonna do suspension wise to account for the heavier engine and blower?
Seer
Bmr k member and moving the water reservoir into the trunk. Corbeau seats and no rear seats. My entire suspension was worked over prior
Mystickeith50
South Jersey
Seer, would the 2.9 mate right up to my intercooler that came with my 2.3. In other words is the 2.9 for the gt500 the same for the 5.0.
Seer
Yes, it would. Thats exactly the same kit that Lethal sells etc. Same lower manifold/intercooler and the GT500 head unit.
