JeremyH
3V Fuel Guru
Thought so and you should have lots of pics.
Yeap they are all at the beginning of the thread.
Alright due to demand I'm going to start offering pre-built hard line to rail setups, this setup is a direct swap for the stock soft line remving the restiction and increasing line size. The efi rail fitting as you can see below has a much larger inner diameter, as well as the hose ends and larger 8an hose. Then the the final efi fitting to go to your hard line at the strut tower to finish it off. (Available in the startlite aqp or ss braid ptfe 8an hose from Fore)
Stock ford efi rail fitting below.
Upgraded efi fitting in the kit.
And here is a shot showing the stock line portion being replaced that runs from the back of the strut tower/wheel up to the railsl. This setup works for stock rails or any aftermarket rail that attaches to the stock line.
To replace the filter you have to relpace the entire line.
Does anyone know if the fuel rail fitting pictured here fits GT500 rails? I ordered this one, but I noticed the stock connector is different on the GT500s than our GTs.
Yes they are different.
Would the AN connector just be the same as the one connecting to the hardline at the firewall?
Its not an an fitting its an efi fitting. In which case its still a gt line on your car right so that end is fine.
I just got my upgraded line...
Anyone know how to remove the stock line? Specifically the fender side fitting?
The tool I have to remove the fuel rail fitting doesn't seem to work for the fender side fitting. sigh
Any help would be much appreciated!!
Just to let people know, I got a fuel line upgrade from Jeremy along with the PPRV delete and it made a huge difference! I run E85 and my fuel pumps were maxed out on my 3" pulley (.500 fpdc). I installed the -8 AN line (PTFE teflon line), fittings, Fore fuel filter with stainless filter element and all new fittings including the Russell one to go on the stock rails and tonight my FPDC dropped to .374!!! That's a 26% difference.
FYI I run GT500 pumps, FRPP 80lb injectors, stock fuel rails and the 40A single boost-a-pump.
Definitely a worthwhile upgrade.
You got any tips on how to remove the stock fitting from the hardline on the fender side? I could not get mine off using the plastic disconnect tools. I tried using the light blue tool.
How is it starting the car without the PPRV?
Give us your feedback.
Awesome results!!
Just curious if you got before and after power outputs HP wise.
