Godzirra
Asian Idiot
Ok...So don't yell at me, butttt apparently a few days ago when I got to roll the window down on some warm weather, I noticed a slight metallic scraping sound coming from rear. Turns out my left rear brake pad is toast and has destroyed the rotor from when I used to not have a line lock. Not a problem. New rear brakes on the way...What is a problem is that some of the metallic "dust" has gathered in some of the corners of my wheel and it seems almost as if it's embedded into the powdercoat....Can this be fixed? I used some clay on it to see if it'd come out and some did come off fairly easy, just wondering if there is a easy fix to this if any of you others had/have experience with this. Or maybe I just need to clay the hell out of them. Is compound and polish acceptable on PC?
Thanks in advance.
Thanks in advance.
Looks like I might have to order some some Sonax now...
