Yeah I'm still going between PD and centri myself. On one hand, all that low end power would be a ton of fun and wouldn't have to be worried about getting into the powerband before passing someone. But I drive my car year round, even in the rain in the middle of January (don't get much snow down here in VA) and I like the idea that it'll still be stock-like down low and easy to manage. I also like the idea that my wife won't have to worry about all that instant torque either. She's no slouch behind the wheel, but she doesn't drive the car often enough to get used to it. Plus I've been told the centri is easier on the engine in low RPMs.
And yet... it would kind of be disappointing to rev the engine up to 3500 RPM to really start having fun.
My wife is 69. She wouldn't even know there was a PD blower in the car. It runs on a vacuum. Unless u either mash the gas, or get the throttle to 80-90%, you won't be into boost. IE: I can get my foot into it pretty good, and keep the boost gauge below 0 psi...and it pulls hard. That's with LT's, twin 62mm TB, and a 94 tune. Want more, then mash it, instant boost...at any rpm. The last thing I wanted is to be driving on the hwy in OD, like 1500 rpm @ 50 mph, then have little to no boost when I put my foot into it...and have to downshift a bunch of gears.
No offense to the centri folks, but imo, a centri is like buying 1/2 a supercharger.
From Dino's prior post. Here's what I found for the Paxton Novi 2200SL HO set up (same as Vortech V3 HO):
3000rpm: 2.1psi
3500rpm: 2.9psi
4000rpm: 3.8psi
4500rpm: 4.8psi
5000rpm: 5.8psi
5500rpm: 7.0psi
6000rpm: 8.7psi
6500rpm: 10.3psi
6700rpm: 11.0psi
Notice between 3000 rpm and 6000 rpm, boost quadruples. At 1500 rpm, boost would only be .5 psi. And just .125 psi @ 750 rpm.
IE: boost is increasing to the square of the rpm ratio's. 6000/3000 = 2. 2 squared = 4 4 x 2.1 psi = 8.4 psi
Sure, the centri is easier on the engine at low rpms...... cuz it's not doing anything.
I have 5 psi, right from idle..... 700 rpm...... but only with gas mashed.
I can have it in 3rd gear in the auto...at a red light. Light turns green, mash it...shriek of rubber...and off we go.
