Status
Not open for further replies.
sbt1320
Maryland
Dog on the big end
~~12.468
06 GT Automatic N/A
3785 lb w/driver
281 3 valve
stock heads
stock cams
stock TB
stock DS
stock k-member & control arms
CAI
Long Tube
Full 3" no cats
Strange struts & shocks
Adjustable upper
Adjustable lowers
3500 stall
4:30 gears
305/40R18 Nitto's (all but worn out)
Top end is weak, need to revisit the tune struggling in 4th gear.
psfracer
billy badass
Valencia, CA
- Type of transmission (by model number)
5 speed stock
Just a pet-peeve of mine--but when listing transmission, the number of gears (5 speed) tells me nothing as both the manual 3650 and the auto 5R55S are 5 speeds. Same for the 2011+, both manuals and autos are 6 speeds.
Since you have 3.55s, I am going to assume you have a 3650 manual trans.
Clipboard
302 4v coyote
N/A no mods
3.55 gear
mt82 m6
335/50/18 perelli
oops i put 335...suppose to be 235 tire ;(
04compgt
- 302 4V, Stock Heads, Stock Cams, Stock Bottom end.
- 6R80
- N/A
- 3.73
- Mickey Thompson Drag Radial 275/60/15
05moneypit
Grove City PA.
Figured I might as well throw my hat in the ring since I joined S197FORUM.
This isn't the best pass the car has done, the day before it went 9.76 at 140 but I will be damned if I can find that slip....I have 5 other slips from that day but that one is missing. All I can figure is I put it some place safe....lol. Anyway the 9.94 is 2nd best and the 10.12 backs that up.
302 3V
4R70W
Paxton Novi 2200
25 psi
3.90 gears
MT ET radials
Lee
  • time slips0001.pdf
Fabman
Children Of The Corn
Pleasanton, Ca.
302 3V
4R70W
Paxton Novi 2200
25 psi
3.90 gears
MT ET radials
Lee
Wow...some fast cars here....good thing I'm stepping up my game here this week.
11SEC3V
Jacksonville FL
[email protected]
http://www.youtube.com/watch?v=V1wGU...&feature=share
2012 Boss 302
Naturally Aspirated
302 4V Roadrunner
MT82
M\T ET Streets 27"
3:73 gears
Kooks headers X pipe
Steeda CAI
3835 LBS w Driver
23APR13
Switched over to E85
11.375 @ 120.69
DA detail between passes 11.31 (1475) / 11.37 +345
Ambient detail 11.31 47 degrees / 11.37 65 degrees
dirtfan71
Marshfield, MO
New PB last night. 13.28 after driving to the track tech, sit with hood open for 5 min and go. The rack hooked really good and I felt 12s close but a major oil down and the track cooled off and my 60' times suffered. This is harder than I thought it would be with my HEAVY 20s. I still am not able to get the 1.9 60' I got when the car was bone stock. After the oil down, I did get some impressive MPH 108.12, 107.9, and 107.84. I see the potential just have to keep adjusting the nut behind the wheel. The corrected DA on the 13.28 was [email protected].
Status
