The Offical Jegs 15" Wheel Thread
05GT281
ole' legend lime
Ft. Laud FL
Awesome. But just one question. I can see in the pics for the rear that the car was jacked up by the pumpkin. Just wondering if the car was resting on a jack stand ? And if the rim was sitting were would be with a tire on it if it was on the ground ( for swaybar clearance)
Freaknazty
KEYBOARD NINJA
SOUTH LOUISIANA
well shit this is garbage the fronts work but rears are small or go with big rears and diffrent style fronts lol damn u jegs
MexGT
Mexico
id like to see the rears with tires and the car in the ground, its def a good option
A John In NJ
Rice Cooker
NJ
Dude, Get the 28x10.5 slicks. Put em on the car and lower it then take pics.....
cjtenney
Mine are overnighted... Be on and pics asap :)...
And be in BR for weekend, break 'em in at NPR Sat. night :thumb:
cool! make sure you spin the front wheel when its up in the air, bc mine rubbed alittle with the 3/8" spacer. It doesnt rub much and not all the way around, just in one particular spot. Let me know how it works out and I cant wait to see the pics, bc thats exactly what ill be running, just didnt want to be the guinea pig!
DarkFireGT
That's awesome. Can't wait to see it with everything mounted. I still can't believe no one had tried these before, especially considering how cheap they are.
Thanks for being the guinea pig. You've made a lot of people happy.
Did you, by chance, weigh the wheels?
black05stxjt
got the slicks from a friend today 28x10.5 Stiff sidewall......i scaled them at 15lbs a piece
ZmanM3
The Evil One
Jackson, NJ
Thanks for the research. You could still put a 9" wide tire on the 8" rim correct?
don_w
Dyno Numbers - Who Cares?
San Diego, CA
I had to use 7/16" spacers with my previous 15x3.5 Weld Draglites. No rubbing.
black05stxjt
the car was not on jack stands just with the jack under the car.....and as you can see in the pic's.....the sway bar is inside the wheel so therefore should be no interference with the tire when mounted.
black05stxjt
all of Mickey Thompson tires are rated for a 8-10" wheel so anything in there line up that fits a 10 will work on a 8
black05stxjt
the biggest thing you have to watch for with the fronts is to make sure that they are torqued even......if not they will rub....had the same thing happen to me.
Stolen 98
Ohio
This is pretty awesome news.
Do you think if you ran the v6 brakes up front you'd still need a spacer???
