Kooks Headers not good?
RED09GT
Equal Opportunity Offender
Kelowna, B.C. Canada
There were several of us that had problems in the 2002-2005 era with fox bodies and Kooks headers. Their experience may be mostly with those cars.
beefcake
Forced Induction Specialist
Official Vendor
Bethel, Ohio
any of the big 3 are good
sw, kooks, and arh
we sell all brands, so pick what you like, and we can get you the best pricing on each
GT E UPP
Toronto, Ontario, Canada
My Kook's with High Flow Catted H-Pipe have been on since '07 with absolutely no problems what so ever. Plus, they look as good as the day I put them on..!!
Chente_04
Kingwood, TX
Just got an update from the shop. The reason they said that was because the last set he installed a week ago one of the header tubes was hitting the frail rail on the drivers side.
Seer
FWIW, the kooks headers primary designs arent setup to compensate for the 5.0's firing order. Take that for what you will though.
Rob72
No Japanese Mustang Here
Baltimore, Marxland
Now if they made a header with the correct primary firing order, equal length, true long tube and merge spikes. That would be a perfect header.
Seer
there are a few brands :D
Chente_04
Kingwood, TX
So are the headers hitting the frame rails a prominent issue with the kooks? Or an installation gone bad?
I already have them here sitting in my man cave :/
Thank you,
-Jorge
spike648
houston,tx
Just curious, what shop are you going for your install? Been wanting some headers my self. Thnx
CPRsm
Thank you,
-Jorge
Those were the bad ones. Problem is when they didn't fit, there wasn't anything you could do. One side had a tube above the frame and the other side under. So no lifting or lowering engine to fix. The new one they sent fit better the the driver still touched on the underside of the frame. Doesn't rattle like the other side did so we left it.
Rob72
Baltimore, Marxland
Thank you,
-Jorge
With Kooks 1 7/8 I highly recommend Prothane motor mounts. The equal length primaries take up a lot of space.
