Apr 23, 2013 #1,281 S stretch Senior Member Joined Aug 14, 2010 Posts 1,665 Reaction score 0 Location lufkin,tx onebadgsx said: I left it and ran the stud/bolt into it. No problems Click to expand... me too
Apr 23, 2013 #1,282 gizmo5 Italian between my legs Joined Sep 29, 2012 Posts 2,788 Reaction score 2 Run the stud in it, done
Apr 23, 2013 #1,283 B Bullett Pwnisher Joined Dec 7, 2008 Posts 1,187 Reaction score 11 Location Mission, TX To those that just got your kits, Ken B will put some hairs on your ass with the tune. Car so far is driving great! Tomorrow we hope to dial it in.
Apr 23, 2013 #1,284 Trousersnake Member Joined Apr 23, 2012 Posts 392 Reaction score 0 Cutting the automatic trans line fluid lines now any tips
Apr 23, 2013 #1,285 Trousersnake Member Joined Apr 23, 2012 Posts 392 Reaction score 0 Do I cut the nylon braided hose right in half?
Apr 23, 2013 #1,286 D DSargent09 Get iT! Joined Feb 23, 2012 Posts 706 Reaction score 0 Every post you make should include pictures!!!!
Apr 23, 2013 #1,287 Trousersnake Member Joined Apr 23, 2012 Posts 392 Reaction score 0 Can't I'm at my limit of pictures
Apr 23, 2013 #1,288 B bigriff85 Member Joined Nov 5, 2011 Posts 183 Reaction score 0 You need a gates 100 and you need to change the bottom idler position for a 2.95
Apr 23, 2013 #1,289 B bigriff85 Member Joined Nov 5, 2011 Posts 183 Reaction score 0 On the bracket whoops hit wrong button
Apr 23, 2013 #1,290 O onebadgsx Senior Member Joined Aug 14, 2007 Posts 1,801 Reaction score 0 Location Houston, TX Trousersnake said: Cutting the automatic trans line fluid lines now any tips Click to expand... I unbolted the trans cooler and ac condenser gave me some more room to cut them right after they turn to head into the cooler then cut them back closed to the trans fittings. Rum new hose
Apr 23, 2013 #1,291 Trousersnake Member Joined Apr 23, 2012 Posts 392 Reaction score 0 Did you have to cut the braided 1/2 inch hose right in half?
Apr 23, 2013 #1,292 O onebadgsx Senior Member Joined Aug 14, 2007 Posts 1,801 Reaction score 0 Location Houston, TX lund racing tuned paxton car Last edited: Nov 27, 2013
Apr 23, 2013 #1,293 Trousersnake Member Joined Apr 23, 2012 Posts 392 Reaction score 0 Wishing I knew if you cut this braided hose that came with the kit in half to make room..
Apr 23, 2013 #1,294 O onebadgsx Senior Member Joined Aug 14, 2007 Posts 1,801 Reaction score 0 Location Houston, TX yes the gates hose use what you need of it to make 2 new hose
Apr 23, 2013 #1,295 bhowardb YellowBlaze Joined May 2, 2011 Posts 151 Reaction score 1 Trousersnake said: View attachment 41506 Does this pop out with a screw driver Click to expand... Are you changing your pulley or something?
Apr 23, 2013 #1,296 Trousersnake Member Joined Apr 23, 2012 Posts 392 Reaction score 0 Don't have an impact
Apr 24, 2013 #1,297 Trousersnake Member Joined Apr 23, 2012 Posts 392 Reaction score 0 Thought if I bolted it on the car and hooked up the belt there would be enough tension to break it loose but it just slips the belt
Apr 24, 2013 #1,298 gizmo5 Italian between my legs Joined Sep 29, 2012 Posts 2,788 Reaction score 2 You need an impact
Apr 24, 2013 #1,299 O onebadgsx Senior Member Joined Aug 14, 2007 Posts 1,801 Reaction score 0 Location Houston, TX gizmo5 said: You need an impact Click to expand... x2...
Apr 24, 2013 #1,300 gizmo5 Italian between my legs Joined Sep 29, 2012 Posts 2,788 Reaction score 2 Page 17 in this thread http://www.s197forum.com/forum/showthread.php?t=90500&page=17
