Beefcake vs BBR
19COBRA93
Ford Racing
Clinton, Ut
On the new block they addressed the weak point at the top inner part of the cylinder, but now I wonder if they're having an issue with the outer part of the cylinder at the water jacket.
This is the new block:
This is where they would break on the production block:
Wicked97
Beltsville, MD
^ correct
I'll say this much. Based on what I know, I will no longer be chasing the 1000whp mark. I am going to sit tight at the 750-800s and call it a day so it lives a while.
I think we have the answer :beer: Look for a new thread coming soon
wow thats crazy. No sense in building 1000 rwhp if you can only get a handful of passes out of it. The 3V blocks never had this problem, correct? Just the new coyote block? I remember taking pictures of a broken coyote a couple years ago when it failed, but at a lower hp level.
I guess if this is true, (that 2 of the new blocks have already failed) that a filled block is the only way to go for that power level. Bye-bye street car though.
the 3v Boss Block had its own set of issues like blowing the mains out of the block since its only 2 bolts.
I think the best way to go when hunting down big power is sleeves. Period.
Or buy a Supra... LOL! Wait, what? :popcorneat:
Or buy the new JPC Block :naughty1:
gizmo5
Italian between my legs
I know whats wrong with it, and you're going in the right direction, but a true 100% fix for 1000-1500whp would be filled and non streetable. Period.
Like MMR does
silverpoison
SoCal
s8v4o
Looks like a "bushing" for the lack of a better word. Wonder if it will cause hot spots along that side?
Wes06
Isn't that what ford started doing with the newer crate motors? Only cast with it instead of an insert.
Looks almost to big in the channel and could restrict flow alitle to much
19COBRA93
Ford Racing
Clinton, Ut
See my post above. The block with the cast supports are the new "test" blocks which aren't available to the public yet (or may not be at all). The crate motors come with the production '13/14 block without the revision.
Wicked97
Beltsville, MD
i will have some more info for you guys by the end of the week.
This is a much bigger area then the ford block. So far we have a good amount of time on a 2011 making 1100 HP with this mod. I dont see how a hot spot will be a problem we have done a bunch of testing with the cooling portion of it. I dont have the info in front of me but i believe we have about 59 Square centimeters of support. Like i said i will have an official release soon.
Not trying to clutter up beefcake thread too much here.
Thanks guys
beefcake
Forced Induction Specialist
Official Vendor
Bethel, Ohio
Thanks guys
your fine, lol, this thread has so much going on lol
Greg Hazlett
Stepping on the Pink Bus
Official Vendor
Chesapeake, VA
Does this mean the 13/14 blocks are ok/stronger than the 11/12's?
19COBRA93
Ford Racing
Clinton, Ut
The '13/14 block is a revised version of the '11/12 block, but I wouldn't say it's exactly better or worse. It uses the smaller, but fine thread head bolts, and the cooling jet ports were deleted. However I've had a '13 block with the cooling jet ports machined out, and one with them not machined out. So they seem to be hit and miss with those.
The weak link is the lack of cylinder support like shown above and that would be with all the '11-14 production and FRPP blocks (potentially excluding the FRPP "test" blocks).
Wnt2gofst
Banned
Columbus GA
A quick look at that car and you'll also see there's no cooling parts to be seen, to further prove it's filled.
Yep. My thing is how are CJ engines lasting. Granted not street driven. But maybe its the racegas vs E85. Maybe slight change in design?
Just Another 700whp DD 5.0
