Engine lift points?
Justinsmt88
Mansfield, Ohio
I'm getting ready to pull my engine out of my 06 GT and am wondering where is the best place to lift from since I'm pulling the engine and transmission at the same time. Just looking to see if and how some of you have done it.
suprchrgd
Noblesville, In
I use one alt hole and one tranny hole. You can run the bolts through the hole from the inside of the block.
05stroker
Never enough power guy!
Bullard Tx.
suprchrgd
Noblesville, In
I always seperate the block from the tranny. lots more work to pull the tranny too, if there is no reason to pull it out, leave it in the car.
Justinsmt88
Mansfield, Ohio
I'm pulling the trans also because I'm doing an auto to manual swap. The new engine and trans are already together and it would be more of a pain in the ass to install it on jack stands rather than putting it in as one.
ILW84U
Edmonton, Alberta
Here is how I put mine in.
07Bossman
How many kept the hood on? I'm terrified I would never get it re-aligned again.
suprchrgd
Noblesville, In
I take mine off, it takes a whole 3 minutes to do. I also remove the fan shroud. With the hood and the fan out of the way it goes in and out very easy.
