muztangman93
When first starting the tuning on my car it started running like crap go wot and it wen full rich maf just went crazy. It ended up being when I pulled my maf out it was covered in rust and still wet with meth on it. Tuned the car without it running great. I relocated the nozzle to a spot that another person is using with a similar setup. Its been hot so I hooked it back up only made a hand full of spirited drives with it hooked up and it was fine. Yesterday on the dyno first pull smooth as silk. 2nd pull it had just a tiny hiccup down low barely noticeable. Well took it out tonight got on it in 2nd for just a second it spun tires so I let out. Few minutes later I hit it in 2nd again and it starts missing. Instantly Im thinking plug but I didnt get to see the wideband so I hit a country road and watch the wideband go wot and it goes full rich. Drive home pull maf and its covered in rust and meth again. I really want to run it to help with heat issues. What the heck is going on. I have it set to come in at 7 psi and go full spray at 14
