Special on TechCo Cold air induction kits!!!
JimIII@JDM
We are offering a limited time special for the TechCo cold air inductions system for your 2005-2009 Mustang. These kits are commonly used on higher horsepower or Saleen supercharged applications in order to allow the mass air meter to work at a higher power range. The stock mass air sensor sits in a housing measuring around 80mm inside. Most companys upgrade to a 90 or 95mm housing. Well the revolutionary TechCo cold air kit uses a 100 mm housing that holds the stock sensor. We have tested this air kit to keep the mass air under its max voltage reading well over 500 HP at the tires! JDM has tested this air kit up to 540 RWHP before maxing out the stock mass air flow sensor. With most aftermarket air kits will reach the maximum voltage of 5 volts well under the 500 HP mark. Limiting the potential power of your S197 Mustang. This kit is a very simple fit, comes with all parts necessary for install, and does require a custom tune.
Regular Retail Price: $599
Introductory Price: $469
JDM Special Price: $419 FREE Shipping and Handling!!
***Thats a $50 savings plus FREE shipping!!!
Product picture
Installed on a 2008 Mustang GT Saleen Supercharged
Direct from TechCo's website:
"TECHCO designed this Cold Air Kit to be the highest flowing kit available. The cold air kit Air Filter Shroud contains a large volume area to fit the high-volume Conical washable/reusable Air Filter, Billet Aluminum Venturi with 100mm Inlet Orifice, Billet Aluminum 100mm Mass Air Flow Meter Housing, and high-flow 100mm Cold Air Inlet Tube. The result is over 80lb/min flow at 5volts with your stock (MAFS) Sensor (MAFS Curve provided with the installation instructions for Required Custom Tune). The Flow Bench tested design of the TECHCO 100mm Cold Air Kit flows 951 CFM @ 19 IN H2O, a 45% increase over Stock and outflows the Saleen 98mm (Rubber & Hard Tube). This Cold Air Kit fits both Stock and Saleen Series VI Supercharged S197 V8 Mustang applications. This Cold Air Kit was featured on the 720HP SMS 25th Anniversary Mustang."
Bullett
Pwnisher
Mission, TX
is there an aftermarket sensor u sell for the kit?? how does it compare to the extreme kit??
JimIII@JDM
It uses the stock sensor but you can use a SCT BA5000 as well. It flows more air per cu in but the stock sensor is what limits the TechCo air kit. With a bigger sensor it will out flow and handle more power then the Saleen kit.
JimIII
craig66
Springfield, Ohio
Is there any clearance problem with the hood with this intake tube? Would I need to use your solid motor mounts? Thanks
JimIII@JDM
There is no need for the motor mounts they fit directly under the stock hood!! No clearance issues what so ever!!
JimIII
