Got A 3v With A M90? Want More Power For Free?!?
corey5988
South-Central KY
Good deal. I can grab other pics too if you need. My pulley is stock. Is it measured from the major or minor diameter of the pulley groove? I can throw some calipers on it and measure.
Department Of Boost
Alpha Geek
Yeah, more pictures wouldn't hurt,
You have a stock S/C pulley right? Yep, measure that up will you? You want to measure from the tops if the grooves.
We need to know
corey5988
South-Central KY
We need to know
I was at work all day yesterday, but I'll try to get that as soon as I get home today.
corey5988
South-Central KY
Damn. I called around and finally got setup with a frame rack and forgot to measure it before hauling it up. I'll grab my calipers and stop by the frame shop tomorrow.
corey5988
South-Central KY
Sorry for the delay. I couldnt get the belt off so I had to measure it with the belt and then measure the belt at the lands to figure the difference. I got 3" even with the belt wrapped around. The belt measured 0.11", which would be doubled getting a pulley diameter of appx. 2.78". That should be very very close. I should have the car back at my shop by weekend if you want me to double check it with the belt off.
corey5988
South-Central KY
I did a bit of research found the exact pulley size is 73mm (2.874"). Also I should be picking the car back up tomorrow, so let me know if you need any additional info or measurements.
Department Of Boost
Alpha Geek
Any news on this?
Sorry, been out of touch for a few days.
Thanks for all the pics and measurements guys. From the looks of this it won’t be a big deal at all. The bypass valve section may get a bit tricky, we’ll see how that lines up. I don’t think this will be a big deal as long as we can fit everything under the hood (which I doubt will be an issue).
corey5988
South-Central KY
Hell I'll put a cowl hood on it if I have to. Thanks for the update. So looking forward to this. I'd love to have one on the car by the time I finish my GT500 front conversion. *hint hint* Haha, just bustin your balls man.
fivelinkcobra
Sorry its taking so long. Our schedules are just not lining up at all. I'm self-employed and work 24/7 on call. But we make this happen.
Jim
AnotherS197GT
Serial Valve Dropper
USA
I don't have a problem coming and getting your car and driving it out to gmitch
:roflmao:
Department Of Boost
Alpha Geek
Thurs would be alot better for me, any time after 2. Jim
Is that when you are getting into Waterford or when you can get a ride? It would be better to get it earlier if possible. We are going to have to let it cool down a while before we pull the blower off.
If there is anything I can do to help let me know.
fivelinkcobra
Give me a call on sun and lets try to meet in person at the show in Dearborn. I will be there from 10-4 ish. We can try and set up a plan then.
Jim
