F1A procharged 05 gt walk around
It didn't until they put this new belt on, its pretty loose so I'm guessing that's y it rattles, u running a cog setup?
muztangman93
Indiana
Na Im running 12rib set up. I had an p1 it rattled had a d1 it rattled the f1 is loud as hell but also rattles like hell. Procharger said it was normal because of the gearing but just sounds bad
Yea well at least I'm not the only one lol we are making similar power with same setup, what compression u running?
Viperrmk
Miami
What do you mean by rattle on your p1 and d1. I'm having a issue with my p1 and a "rattle" when it's at idle. Sounds like something is buzzing/ rattleing and it's only with the procharger as I have taken the procharger belt off and it doesn't make the noise. Just wondering if its a normal thing or if I should call Prochager some more and bitch.
Btw sonicblue, car sound f'ing amazing! I was sitting over here drooling!
