Barton Shifter woes
James33411
Royal Palm Beach, FL
Does anyone else have a Barton shifter in your car, that you've come to hate? Had mine installed and got an old bushing/mount design. Was very difficult to get into 1st, 2nd and reverse. I was advised that there were problems reported with a few shifter kits and that a new bushing would be sent out.
My shop ( No complaints with them at all )installed the new rear support bushing and it was smooth as silk for the first 1500 miles or so, now its back to the same damn thing. If I still had my stock shifter, I'd re-install it.
I have to fight to get it into 1st, 1st to 2nd takes so much force that I could never have my wife drive my car. And yes, I have tried at all speeds, including at idle... And yes, the clutch is fully disengaged.
I understand the remote linkage thing and how Ford should be forever shamed over it. I also understand that if there are any major changes to the chassis that it can distort the geometry, like bending the car in two, mismatched motor mounts and so on. None of which describe anything that I've done to my car.
I have this thing..... that I will give anything a second chance.... I am having a struggle with deciding to call Barton to ask for another bushing or just saying...... time is up!
Any thoughts on MGW units?
:horseshit:
BLACK-MACHINE
living my 2nd child hood
dang i was just about to pull the trigger on one for my 09-gt, now im going to wait to see what others say.
NaS197
MGW all the way
Sent from my EVO using Tapatalk 4 Beta
:horseshit:
I've had an MGW with a 3650. It made a big difference. It's a good unit and worth the money.
TJL442
UP of Michigan
I have a Barton installed and don't have any of the issues you describe. Is it smooth as a hot knife through butter, no but it is quite a bit better than my stock shifter.
Tim
Bill220
I really like my MGW shifter. I would buy one again in a minute.
I loved my MGW (until I replaced the transmission and could no longer use it). Not only are their shifters very well designed and built, but George and company all seem to bend over backwards for their customers. Even those who have bought their shifters second hand get excellent product support and service.
ksack
I've got a Barton and Che limiters on my 06 and no issues. Give them a call
GT E UPP
Toronto, Ontario, Canada
Sorry to hear James. No Problems/Issues here at all !!
Still love it....I had mine installed about a year ago and there's absolutely no comparison to Stock,
Hurst Competition Plus, and Billet Plus shifters !
HellsBells
620/677
SoCal
Looks pretty cool...except you gotta cut up your car for 2011+ & looks like clearance issues on lowered vehicles.
Sent from my SGH-T989 using Tapatalk 2
You just have to cut off two studs...
And have you seen my car? Being lowered is not an issue--there are parts of the frame much lower than the brace.
James33411
Solve 99% of your shifting woes the easy way:
http://www.cheperformance.com/prod-208.htm
Wont fit on a turbo car, it appears.
And on another note.... I don't think I should be required to spend $200 to make a $300 part work. Since when does a shifter require a supporting mod........ In this case, a mod that would make it work as intended.
(BTW, this was not intended to be a MFG bashing..... Just looking for advice and recommendations)
HellsBells
620/677
SoCal
I use the brace and a stock shifter and I have NO shifting issues at all. I never implied you had to spend more money to make a part that doesn't work work.
Sucks that you spent $300 and then, because you couldn't install it yourself, spent more money at a shop that probably installed it wrong.
My advice and recommendation is to learn to drive.
