Are you going to replace the plugs?
No, I have a set of Brisks that look pretty good. A hell of a lot better than these. lol But since I was not experiencing any kind of misfire. I figured they are fine and will run them hoping they will eventually clean them selves out. I'll stop running Torco at the racing events. I should be OK to run 91 without issues.
During the spark plug inspection, I also replaced my FRPP coils (stock brown boot coils) to these:
I know, I know...nothing beats stock. But I just wanted to try them out.
Here is some info on them:
http://www.performancedistributors.com/soscoils.htm
For Ford 4.6 and 5.4 V8 owners, the distress calls for the COP (Coil On Plug) Ignition Systems have finally been answered! Performance Distributors is now offering the SOS (Sultans Of Spark) high performance coils for the Ford modular V8 engines. Advanced technology has allowed us to pack more electrifying voltage into these small coils for tire roasting performance out of your late model Ford V8. The SOS Coils are designed with increased windings to boost spark output up to 40,000 volts! That is a 60% increase in spark energy over the 25,000 volts produced by the stock coils. The higher voltage along with increased spark duration will allow plug gaps to be opened up to .065". This larger gap exposes a hotter spark in the combustion chamber for an increased burn of the fuel mixture, resulting in more horsepower and better fuel economy. Additional benefits include quicker starting, smoother idle and greater throttle response. The SOS Coils are designed utilizing proven technology, the same quality that has gone into our DUI and Screamin' Demon Coils. No gimmicks are used for our coils such as "zero resistance" or tricked out "rings", just pure hardcore ignition performance from the leader in high performance ignition systems. Recent testing
on a 1997 F-150 with the 5.4 concluded that the SOS Coils reduced 0-60 times by an average of .84 seconds compared to the stock coils. That's performance you can feel! The SOS coils are a direct replacement for the factory coils and do not require any special modifications. Also available for the V10 engines. SOS Coils are covered by a one year warranty.
At startup, I noticed the car required less turns to start and the idle feels a lot smoother/stronger. Throttle response is crisp; but in all honestly, not sure if its any better than stock. Or is all this a result of eliminating the PCV system... lol
Here are pictures of the Bank 2 plugs:
Plug #5
I noticed this on all the threads:
Seems to me that the shop that last messed with the plugs put some type of anti-seize or something. Weird. My understanding is that you're not supposed to!!!
Plug #6
Plug #7
Plug #8
Inside plug #8
So these look a little better I guess.
When I smelled the plugs, they smell exactly the same as the fluid/oil that comes out of the catch can/oil separator. Unless that's how a combustion chamber is supposed to smell.
Also, after replacing all the plugs and installing the new coils, I cranked up the car with the PCV system removed, meaning the supercharger elbow is plugged along with the intake tube.
While idling, I noticed the passenger side is blowing air...a lot more than the driver's side. The driver's side has a faint blow. If I plug the passenger side hose, then the driver's side increases in flow. PCV valve in the driver's side works. No air in, but all of it comes out.
Let's see what eliminating the PCV system does. I am hoping the plugs will clean themselves somewhat...enough to see if there is a difference.
In the meantime, I will source a compression and leak down testing tools.
Thanks for all your help guys...not sure what I would do without you guys.
Gerald, I have a set of NGK Iridium cold plugs that I just pulled out yesterday. You are welcome to use them for testing if you want. I'd really like to look at your pcv setup too. Do you work dayshift? I'm home right now and have the evening free.
Thanks Bruce, I have a set of spare plugs that are much cleaner than these; they're Brisks though.
I took the day off today to tinker with the car some more and finish the breather catch can install. I'll be home all day... lol
FYI...I run a oil ring gap half of what you do.... .015 is what I run on stainless rings.
And no oil issues? Hmm, I'm still hoping its either the rings that have not seated yet or it is indeed the PCV system causing me grief. I also hope its not a head issue.
I am planning on my next oil change, to just dump some cheap auto parts oil in there in hopes of sealing the rings once and for all.
What plugs are those? They look to cold, shouldn't be black on the bottom. The Torco makes reading them difficult. #3 and #1 are without a doubt a problem but you can't tell for sure from just the plugs if it is rings or valve seals.....hell it could be like others have said and may just be sucking oil into the intake but I would expect to see both banks of plugs looking like that.
Compression test would help point you in the right direction without pulling the intake to check for oil in the intake or from the valve seals.
Proper way to do a compression test is to pull all the plugs. Unplug the injectors or pull the fuel pump fuse. Hold the throttle wide open and crank the engine and get 3 hits on the compression stroke, you can do more than three hits but just do all eight cylinders the same. If all eight are with 10-15% then pull the SC and look for oil.
I will be happy to send you my leak down gauge but I think you will be able to find the issue without it.
Here is a link on doing a leak down
http://www.carcraft.com/techarticles/116_0406_cylinder_leakdown_tester/viewall.html
Also some videos on youtube.
Goodluck!
Lee
They are the NGK Iridiums...stock 12mm plugs for the 08-10 heads.
