I feel like I'm in an episode of "Ground Hog Day" combined with a bad dream...
Oh Great and Wise Barbaro, if you are right and the Cortex package you outlined is indeed the "supercharger for suspension," how many laps at a 2-mile track will I get before it heat-soaks? Can I buy a larger intercooler for it? If it's "the bomb." is there a way to defuse it before it blows, or at least a way to delay the fuse so that I can get through tech at the end of the race? Is it hard to get a drive-belt down to the rear suspension?
Without even touching your main assertion, so many of the things you say are just flat wrong, and that doesn't help your position at all. Torque arms do NOT "reduce body roll." Springs and swaybars do that. Nobody denies that a torque arm reduces rear squat under acceleration (and does so by increasing the anti-squat percentage), but there are a variety of ways to make that happen, and the torque-arm isn't the only one. In fact, the rear grip kit includes relocation brackets for the control arms, which is the prime way of increasing anti-squat, and does quite well with a 3rd link yielding essentially the same effect. From Norm's numbers, the TA by itself does increase anti-squat by a few percentage points, but the big gain is from the brackets. I'll let him run the numbers if he wants, and if he hasn't been utterly disgusted by this thread. Anti-dive (and the corresponding increase in rear brake efficiency) can better be handled at the front end, even though the TA does contribute an analogous component.
The "experts" that you cite (and yes, I do consider Filip and Bruce Griggs to be experts) consist of two manufacturers and a sales outlet. I notice that NONE of them have gotten involved with this thread. Too busy? Very possibly, but with your completely fan-boi approach as cheerleader, I wouldn't blame them from distancing themselves.
As to your assertion that "the gobbleygook on this thread is for techies and is designed to confuse you," that strongly implies that we "techies" are deliberately obfuscating the information, when it's pretty plain we're doing the exact opposite. The reason that we're trying (again and again) to QUANTIFY the actions of the suspension package you're recommending is to understand (and let everybody else in the world understand) exactly how the system works, and thus reveal what the benefits truly are. We want to break it down to terms of wheel rate, anti-squat, anti-dive, instant center, roll center, etc., not "the bomb," "supercharger for your suspension," or other nebulous, unsupportable claims. We leave that for "mods" like vortex generators in the air filter, exhaust whistles, and other marketing-driven nonsense like that.
You persist in portraying yourself as a persecuted messiah, spreading the one true word, and you just ain't all that... Remember that the definition of insanity is doing the exact same thing, the exact same way, and expecting a different result. If you would just spend a bit of time NOT posting, but instead studying suspension systems, or at least googling the terms, you would be in a LOT better shape trying to support your position. I don't think any of us are arguing that the Cortex rear grip package is flat-out superior to a stock rear suspension. The two most effective changes you can make to the stock S197 suspension are dampers and springs. I don't think you'll argue against that either. Those two items alone provide ALL of the benefits you list in your latest missive: Reduce body roll. Check. The increased spring rate means that with a given load transfer, the suspension will not compress as much. Reduce nose dive. Check. Same exact reason. Reduce squat. Check. Again, the same exact reason. In addition, those two items will address your "ride quality" as well. Better dampers will tighten up the chassis response to high- and low-speed suspension jounce and rebound conditions. The main difference between a "Cadillac ride" and a "BMW ride" is in the damper rebound curves. A decent set of adjustable dampers on an S197 will go a long way towards being able to hit your target "ride quality" characteristics.
So, let's take a hard look at the Cortex rear package. It includes:
Coil-over dampers. Increased spring rates, better dampers, adjustability for ride quality. Works equally well with TA or 3-link.
Rod-end lower control arms. Eliminates bushing deflection. Works equally well with TA or 3-link.
LCA relocation brackets. Allows a major increase in AS%. Works equally well with a TA or 3-link.
Watts link setup. Arguably better lateral axle location over a Panhard bar. Works equally well with a TA or 3-link.
Torque arm setup. Offers minor increase in AS%; arm length provides better control of axle rotation than a stock upper control arm and rubber bushings. Not necessarily true of an aftermarket UCA and Heim joints.
As a package, I'm sure this works well. VERY similar to the Griggs package, which I'm also sure works well. The torque arm, however, is NOT the major contributing factor here, it's all the other stuff surrounding it that create the effects you describe. THIS is why we're constantly beating up on your posts. They're mis-informed, you're mis-informed, and worse, you won't admit that, instead taking pot-shots, dropping non-sequitur arguments, and acting as if you're being persecuted for being leading-edge and non-comformist. In the end, the TA is still 1970's technology. When applied to the abortion that was the FOX/SN95 quadra-link suspension, it was a night-and-day improvement. Just because a couple of manufacturers re-tooled to transplant their SN95 kits onto an S197 doesn't make it leading-edge. Think about subframe connectors. the S197 has a torsional rigidity that's higher than a Gallardo AWD, but that didn't stop people from suggesting we "need" subframe connectors to reduce chassis flex. I'll pose a question for all thinking readers: Given the information we have about suspension operation, is it possible that a torque-arm is a solution to a problem that doesn't exist? Not you, Barbaro, you've already made up your mind, and no amount of information or "truth" will change it, or even incite thought.
