crownaviation
http://www.tudyno.com/
Just sit there and pump the pedal!!! Promise it will get stiffer!!!
Just pump it like 100 times. lol
you sir are a studJust sit there and pump the pedal!!! Promise it will get stiffer!!!
you sir are a stud
You havnt read much but I have already replaced all that
was he referring to the shims? i would measuring out the cams. i am on board with the possibility they fucked them up when they ground them. sure would not be the first time
I have a set of stock Cams you could try if you want. Just cover shipping both ways.
The only crazy thing about that is they came off Silverpoisons car and he says there were no issues? So I don't know lol... All I do know it the has a valvetrain rattle until it reaches operating temperature then runs damn smooth... I am starting to worry that I have spent so much time trying to diagnose the problem that seating the rings are going to be a bitch if they seat at all...Im hoping my BR-30 saves my ass...
There combo worked great on my car never had a single issue with the combo and is proven to run and make power. Only thing I can think I would have changed if was keeping the combo was probably lifters but they were fairly new.
well regardless its one more piece of the puzzle you could eliminate if you measure them / use them and you still have the same problem.
